Force 150 powerhead swap
Detritus
Hi, first time poster on here, been a reader for months. So, I have a 1993 or 1994 force 150, serial # 0e022214, did so much work to that thing to try to make it not melt down. Impeller, checked thermostat, water jacket check, compression check, redid the carbs fuel system, etc etc etc.
Well, Saturday, it melted down anyway. Cylinder 1 piston is trashed, and 5 looks a little crummy too. I'm guessing that the crank case seal(s) went bad, and there wasn't enough vacuum sucking in fuel and it ran lean to death. Carbs needed to be adjusted 2 or more turns out for it to be happy. Any thoughts on the crank case seal theory?
Also, I found a running (supposedly) force 150 from 1991 missing a starter, trim tilt pump, about 3 hours away for $500. The question is this. Can I take the long block from that and bolt it onto mine?
All of my electronics are good, cdi stator, switchbox, all new rubber, fuel lines, fuel system, clean fuel recirculating system, and everything, spotless carbs. My shop manual says something like 1991J to 1994, the assumption being J is the part of the serial number that is included in the book all the way up to 1994.
I was hoping you guys would know if this idea will work, or what to look for on his motor to find out if it will or won't. Serial number? Engine component telltales?
Anyway, I've been impressed with you guys in your force knowledge, I'm sure someone knows .
Thanks in advance,
Jack
jerryjerry05
The blocks should swap.
To insure the new one's good??
Take your starter and do a compression test, no reason to buy an anchor right off ??
IF? the blocks good?? it might be easier to just swap motors? and change the pump??
Detritus
That's the guy I was hoping to hear from, the great force guy Jerryjerry. Thanks for the info. I missed out on the motor though, so now I have a lot of super clean force 150 parts. Cdi stator, and cdi switchbox, low hour lower unit, etc, with no powerhead. Guess I'll keep my eyes open.
Thanks again for the response.
Jack
