Re: Force 150 head gasket questions
You're probably right in that they are trying to maximize the chances of success while minimizing their liability. It is important to double the oil to 25:1 ratio during break-in, and limit engine speed for the initial few hours. Also generously coat the whole piston and cylinder walls with 2-stroke oil when putting it together.
I've seen several motors with new Wiseco pistons where the owners have not followed any break-in procedure or only broke it in for 20 or 30 minutes and went to WOT only to find out that they wiped out the rings and pistons bad enough to have to replace them. I've also seen others where it did not do any harm at all...go figure. It seems that water cooled 2-stroke outboards can be less forgiving when it comes to breaking-in new pistons/rings as compared to automotive 4 stroke engines.
I would follow the break-in procedure as best I could to be safe.
