gregmsr
Thread starter- Joined
- Sep 20, 2006
- 391
I searched but not found any posts on this problem that can help me. I have the 125 hp on a 89 Capri. I've got slack getting worse in the steering. The motor will rock side to side slightly while under way causing this "bumping" in the steering wheel. I looked at everything associated with the steering and cannot visually see any problems. But, there is 1.5 to 2" slack in the steering wheel.
Is the cable getting worn out or is there some adjustment under the dash? Is something coming loose? Everything looks fine on the motor end, the problem is at the steering wheel end.
Any help appreciated on where to look.
