Force 125 no fire
mstryfan
We are new to boating. Have a '84 Force 125 outboard. Ran last time on Memorial Day weekend, and did fine.<br /><br />Tried to run today 7/4 and engine tried to turn over, but got no fire.<br /><br />Had Motor completely gone over by mechanic in April. Everything ran fine till now.<br /><br />What could be problem??<br />Help...<br /><br />------------------<br />Homeboy & Mstryfan
sony2001
Re: Force 125 no fire
From your description it seems the starter motor cranked the outboard motor slowly or too slowly to fire up. Am I right?
evin300
Just dont forget the good ole kill switch, happened to me once, I didnt have the right laniard so I rigged it to push the button in and really got fooled, the button has to be depressed quite a ways, or maybe its bad?
Walter
Lot's of things could result in a "cranks/no fire" situtation. If you could determine if it's no spark or no fuel that's causing it not to run would be a good place to start. You say the engine "tried" to turn over. Did it crank normally or slowly, as if battery was low? Something easy to check would be to ensure the "kill switch" (if so equipped)is in the "run" position. Good luck!
