FORCE 125 Help I think my pee is too warm
pwilson
My Force 125 has new impeller, and the water flow is good, but the water stream coming out of the "POWER FLOW" is hot enough to create steam on hot day.My alarm is not going off.Is the steam normal. The water coming out of the to pee holes is pretty warm, but it will not scald your hand.Please help, Thanks. P.W.
12Footer
Re: FORCE 125 Help I think my pee is too warm
My first thought is everything is fine. But stick an outdoor thermometer provbe into the stream, and verify it is less than 160degrees, 120degrees being best.<br />The hand werks fairly well for this testing, because if it got too hot, iot would have scalded you.
