force 125 cooling system problems
dogboy8
I lost water circulation and overheated after sucking up a bunch of mud. I have the water pump out (looks pretty worn, but I would think it should still be pumping some), and I found one piece of rubber (does not look like it came from the impeller) that could have ben at least partially obstructing water flow. How would I go about try to flush any debris out of the system before I install the new pump??? Thanks a million Greg
