Re: Force 125 1251x6a Top two cylinders not firing
Welcome to iboats.
Your motor's ignition has 2 cd modules , each module provides spark to 2 cylinders.
If one module goes bad, 2 cylinders have no spark.
It COULD be a couple other issues, but the odds are on the cd module.
To verify, Label all the wires on the 2 cd modules, then take a digital photo and make note of all the wire locations and colors.
Remove the 2 cd modules, swap them with each other, then re-attach all the wires.
If the cd module for the top 2 cylinders was bad, it will now be hooked up to the bottom 2 cylinders.
Check for spark, if there is now no spark on the lower 2 cylinders, replace the cd module with a new one.
Post back with your results.
