Re: Force 120hp cuts out while running at any speed
Let's take a guess here--difficult without more info, but if it stops abruptly and at no particular speed, disconnect the blue and white wire from the ignition switch or if that is not easy, disconnect from the engine terminal board. If the problem stops, replace the switch. This assumes, of course, that Merc has not changed the stop circuit wire colors.
Even the Merc ignition was independent of the other engine circuits and charging circuit so a short within wiring should not cause the engine to stop. The only wires you need to check first are the two associated with the stop circuit. A short to ground here will cause the engine to stop, and it may restart immediately or it may take a while before it will restart.
If they have changed the colors, buy a manual and disconnect the stop circuit wires.
