power_safe
Thread starter- Joined
- Dec 10, 2007
- 1
I have a 1995 Force (OE121203). This come with the standard ignition CDI system.
The problem was that I bougth a CDM complete system (stator, trigger, regulator, CD modules and wires) and I did place in my engine. However the motor not run. After to make some mesures I found that the trigger dont send the proper signal (200mV aprox ea). I found in this forum that when somebody upgrade to CDM system also is very important replace the flywheel because is sure that the trigger dont work property.
OK. my confusion is that Force have a lot of differents flywheel and I dont know which is the proper to my engine. After to make some investigatons I think that the proper part number may be MER261-9008A36. if we search this part number in a web page of a Mercury dealer, then show this:
MER261-9008A36 [FLYWHEEL ASSY ] has been Superseded by
MER261-9008A54 [FLYWHEEL ASSY ] has been Superseded by
MER261-859236T6 [FLYWHEEL ASSY ] has been Superseded by
MER261-878227T8 [FLYWHEEL ] has been Superseded by
MER261-859236T07 [FLYWHEEL ]
Also a friend told me the the P/N: 261-9007-C2 could work.
Somebody have any idea to help me???
Thanks in advance.
Thanks in advance.
