Force 120 tilt/trim repair success
tphowell
Just a post to thank Lt. Cmdr. RRitt and Adm. Clanton for their posts giving advice to others. After reading several of their responses, I felt comfortable enough to identify my tilt pump (Eaton) and repair the trim cylinder which wouldn't hold the engine up for about $20 and half of that was for three original bolts on the trim cylinder (originals sheared off). Replaced all Orings from a hydraulic parts house here in Dallas for $11. Main problem was the trim piston oring had about a half-inch piece broken off.
Just wanted to thank you for helping people like me who like to do - or at least like to try to do - everything themselves.
tphowell
Re: Force 120 tilt/trim repair success
My math needs work. Total cost was about $25.
RRitt
wonderful. freshwater cylinders are an easy fix. saltwater is at the completely opposite end of spectrum. You should go back and buy two more bolts. If three snapped then the other two are damaged for sure.
