Re: Force 120, pumps water but overheat buzzer is going off
Sounds like the thermoswitch on the head is too sensitive. As faras the thermostat, USUALLY, corect installtion is with the pellet toward the hot side, the block However, on olde Chrysler engines there was not enough room and it went in opposite. If you have enough room install it with pellet toward hot side, if not, put it in the other way. In either case, there will be a bleed hole either in the thermomeer flange or a small notch cut in the hole where the center seats. Install with this bleed hole up so hot water will tend to wash over the pellet.
