Force 120 overheating at full speed
Docbarn
I have a 1998 Force 120 that the over heat light and buzzer goes off when going full throttle, top speeed of about 45 mph. Warning light and buzzer does not go off at less then 30 mph or trolling speed. There is good flow out the pee hole at all times and the engine seems to run fine. Any suggestions.
imported_bjs
Re: Force 120 overheating at full speed
thats a tuff one is there water spraying out at w o t?i had same problem with mine motor was plugged up with sand on exh.side of the motor.i also installed water pressure gauge.impeller could be bad.i bought a water pump housing kit.good luck
roscoe
Perhaps the motor is trimmed out too far and the water pick is partially out of the water? Not supplying enough water?
