Re: Force 120 lower unit question?
I have a 1990 90 horsepower which has the same midleg as your 120. I have replaced the lower unit with an earlier unknown year lower unit. You can buy any lower from 1982 Chrysler to 1990 Force. --Any three or four cylinder except 70 horse Force.
Although the 1990 has a different water pump and a two piece drive shaft, all earlier units will bolt up to it with no problem. But you need a complete lower with pump included. Pump outlets are the same. Crank splines are the same and drive shaft length is the same AS LONG AS you are replacing a 20 inch long shaft engine with a 20 inch lower unit or 25 extra long to 25 inch.
If you really want to wake up your 120, see if you can find a lower unit off a 90 horse. It has 2 to 1 gears. If you do find one and you re-prop 2 pitches higher, RPM will remain about the same and speed will increase about 3-5 MPH
