Josh P
Thread starter- Joined
- Aug 26, 2009
- 328
OK i need help, i have a 1991 force 120, problem is it has a rough idle kinda like its only firing on 3 but trying to fire on the 4th. I have checked compression, dry test came up with 150 all across the board, so i replaced plugs , no change so i pulled the carbs and cleaned them, they had some junk in them. Set my idle screw at lightly seated to 1 turn out , fired it up same problem. Tried adjusting the idle screws it doesn't smooth out but it dies so they are doing something. If i try to rev it a bit by the linkage ( i know its not advancing the timing but it should still rev up to a point) and it dies but fires right back up> I have included a video sorry its from a cell phone, crappy quality. But you only really have to listen to it. I need help please. forgot to put have checked spark while cranking and all was good are this known to not fire when under compression? but fire when cranking?
Force 120 rough idle
