#1gatorfan
Thread starter- Joined
- May 31, 2010
- 1
I could use some serious help. I was out fishing yesterday and was idling out of a cove. When i gave it some throttle and the boat was trying to get on plane. all of the sudden the boat lost its momentum and the RPM's shot real high. I pulled the motor out of the water and the prop was still spinning. So i lowered it back in the water and tried it again. I put it in gear and started to give it some throttle and again the RPM's shot real high and i was not moving. Its a 1998 Force 120 Hp outboard. It seems like when you put torque to the prop nothing is happening but at idle the prop turns with no problem. Any help on this matter would be greatly appreciated.
