hello ! my 3.0 GS PNCA ( year 1996) has a pipe which runs from the fuel pump to the carburator ( and connects to a nipple under the flame arrestor on the back) . it looks like a suction hose .
i saw now that the pipe was broken so replaced it. before that you had to pump with the throttle when the engine was cold, but started instantly war- now it starts cold better - BUT it seems to have a poor idle and you have to advance the throttle to keep it alive when previously it ran smooth !
i have to say that the smooth running was on muffs yesterday with torn pipe and today, with the new pipe i put the back of the boat in the water on a slip to test it.
please excuse my ignorance but my main experience is on outboards not I/O - may the poor idle come from a very deep sitting back when you just put the back of the boat in the water ? i want to replace antifouling and gearing oil so did not put it fully in the water and stopped the testing since i was not sure if the low sitting back will not introduce to flood the engine via the exhaust. ( but i may be wrong here)
finally... does anybody have a trick how to unscrew the drain plug on a sx drive ? mine is such tight i simply cannot unscrew it- tend more to destroy the drain plug !
thanks for any help !!!
