For the big block operators, cam recessed about 3/8ths of an inch rearward
Bt Doctur
Like the title says, my buddy`s big block was acting funny. low compression , slight moisture issue. pulled the head and found the gasket blown between 2 and 4.
#4 intake lifter depressed about a 1/4 inch more than the rest.So new lifters and a head check coming.
What we did find that is worry some was the fact that the cam is recessed about 3/8ths of an inch rearward. the lifters are not riding in the center of the cam lobes.
A few of the lifter bases were rough on the edges but were able to be removed from the block.
Its my first time inside this motor so I have no history on it but have never seen a can ride that far off. The lifter edge appears like it was striking the adjacent lobe with its edge.
If you`ve seen this or know of someone who has, pass it along. Need an answer to look for when I start the dis-assembly.Suspected the can bolts are way loose
and it allowed the can to travel rearward.
Ayuh,.... Ain't seen it, but isn't the distributor gear all tore up,..??
Bt Doctur
with the weather here all we had time for was pull the one head, will report on that. never looked but you right . It should show some serious wear.
NHGuy
Post it on the hotrodder forum and offshore only. Tell them also whether it's a roller or flat tapped setup. Those guys are good on this stuff.
