wtxpatrick
- Oct 3, 2009
- 37
I finally got to take pics of the engine mount and height. At planing speed, I have a symmetrical V shaped rooster tail shooting up and the boat catches a little water from it. The load in the boat at the time of the test was around 400 pounds. Engine is centered on transom and seems level. Mount seems to be to spec. Engine could adjust up but not down. I get a smooth ride at planing speed, no porpoising, or bouncing. prop is 13 1/4 x 17, no tach but RPM sounds ok as does speed. there is no hydrofoil on motor, but I did purchase a Stingray on ebay for it. Cavitation plate on motor is true, no bends or distortions on the metal. Engine is a 70 HP evinrude, mounted to a 15' Magnum fish and ski type boat. Boat is rated to 90 HP maximum. 750 pound maximum load. Boat model # is 150. Fiberglass construction. Tri hull design. weight is unknown. The cavitation plate looks to be about 1 3/4 to 2 inches below the bottom of the transom,as the photos will show. The motor tilt setting was in the 2nd hole from the front, I moved it out to the 3rd hole, but it made no difference. Possibly I need to move it all the way forward ? The tilt is manual, no power tilt, I really miss that. The only thing i see is the lower engine mounting bolts stick out about 2 inches and the washers are square 1 1/2 , kinda large and possibly wrong type. I bought the rig from an electrician.
Anyone got any ideas ?
Thanx
Patrick
Thanx
Patrick
