biederboat
Thread starter- Joined
- Feb 13, 2005
- 94
This motor just keeps pulling me in further than I ever hoped it would but there's a slight glimmer of hope here. Bought a boat knowing it had a frozen 1996 90 HP Force (aka "Farce", I know). I was basically relieved that it was frozen when I bought it, thinking there's a good excuse for replacing it with a 4-stroke. Being the tinkerer that I am, I start fiddling with the thing and got it to turn over, one cylinder has no compression due to a failed head gasket, leading to water in the cylinder = rust = frozen head. So, here's where I am now: The piston is pulled out via access by removing the manifolds. The piston looks "okay", needs new rings, and the cyl bore in the bottom stroke has some light rust, but looks like it would clean-up okay with a honing. Now, I don't want to disassemble the entire power head, way too much money or self labor in a Force. So, is it possible to do the honing without disassembling the rest of the powerhead? My main concern is that the honing process might generate debris which would end up in the crankcase and eventually destroy bearings. I've attached a photo so people can see exactly what I've tried to explain.
Anyone have experience in this area? I'm pretty confident (enough to spend money on new gaskets, etc. and spend time) that if I can fix this, the rest of the motor will be fine to use until I replace it with a 4-stroke. On the other hand, selling it as a basket case is what I had planned on when I bought the thing and I only have about 2 hours in disassembly so no big deal.
Thanks,
Biederboat
Thanks,
Biederboat
