Re: Fogging Oil Filled Carb
Not much, Netzoe. The fogging oil is less caustic than decarb cleaners, and as long as <br />you do as J.B. sugested,(remove plugs and let it spit the excess oil out), you'll be fine.It may foul the plugs once before it clears completely,so run it for a few minutes on the muffs,and then change the plugs out before hitting the water.<br /><br /><br />------------------<br />Sandbar? Sandbar? I don't see no stinking sanDBARRRrrrrr!!!
