Fogging Oil Didn't Cause Stall Out
stereomike
I am winterizing my boat for the first time, when spraying fogging oil into the carbs it caused the engine to sputter but it would not stall out.
After I went through a full can, I shut the motor off with the key.
Is this OK?
Laddies
Banned
Re: Fogging Oil Didn't Cause Stall Out
Thats not uncommon and the engine should be fine.
Irv964
I agree, but if your still concerned I would remove the spark plugs and give each cylinder a little squirt to ensure the oil gets around the piston rings.
Also, you didn't mention if your motor was a 2 stroke or 4 stroke, I assume a 2 stroke? Fogging a 2 stroke is less critical because of the constant oil in the gas, some people don't even bother but at the very least I would still put some down the cylinders....Irv964
