Re: Foam under floor
Definately replace the foam. As for the trailer, make sure the tires are the proper size and type for the application. Make sure they are aired up properly (not too little or too much). Also, make sure your wheel bearings are properly lubricated and properly tightened. If there is too much resistance, it can heat the hub, which if hot enough can heat the rim, which can expand the air in the tire, and if the tire is under/over inflated, it'll pop. Good luck.....
