Greetings once again to the Board;<br /><br />I have a few questions...<br /><br />1. My starboard foam is holding some water but it appears mostly on the bottom about 1/2" above the hull. In some areas there is a 1/2" gap between the foam and the hull - in others the foam is in full contact and when removed there appears to be an imprint of the woven 'glass on the soaked foam. My question is: Is the off color soaked foam degraded resin or is it just the nature of this foam to turn brown when waterlogged (appears to be a yellow closed cell type of foam)?<br /><br />2. My 3/4" marine plywood stringers and floor are wet, but (so far -- knocking on wood) no rot. Should I replace or just cover with epoxy resin?<br /><br />3. I will be cutting and epoxying in place 1" PVC through the bottom of the stringers to allow for drainage to the bilge...but where and how often along the stringer (bow to stern) should the limber holes be located? Right now my focus in the stern area of the boat and I plan on 'glassing in a limber hole in front of the motor mount.<br /><br />Regards,<br /><br /> --rml
