i'm guessing i kept somewhere around 65-75% of the flotation and kept my drainage. it's not locked into the stringers and hull like it normally would, the blocks all pull out.
test run...50 ml part a + 50ml part b...made well over 3 liters (86 degrees today)
i used trash bags to line the area and some shims of wood that could be removed to make pulling the foam out easier
poured the foam, let it set for about 15 mins, pulled the shims...bags came off easily
some areas need to be trimmed but that's pretty easy with a hand saw
the deck fits pretty tight on most of the foam, it's locked together better than i thought it would be. i going to pour some 2-3" sections in bags to put on top of the exhaust pipes to help muffle it some.
deck soon, carpet is already here waiting...
