Foam Board not made in 1 3/4 "
Swampfox88
I need to replace the foam in the floor of my boat, the original foam is 1 3/4 and the height of the ribs is 1 3/4 thick.
I want to use the pink or blue foam board from lowes, but they only carry 1 1/2 or 2 inches.
I am putting the factory aluminum floor back down.
My idea is to use 1 1/2 foam board and then on top of this use a 1/4 piece of plywood covered with spar urethane. Would this work?
I never want to take this floor up again as its about 200 rivets to do it.
Any suggestions are welcome. Thanks
_________________
1976 Duracraft 1436
16Ft Coleman Scanoe
5 hp Gamefisher
mavryk
Re: Foam Board not made in 1 3/4 "
Dow board is available in 1/2", 3/4" and 1", 1 1/2". You can also get "fanfold" foam insulation that is 1/4" thick. To get to 1 3/4", purchase 1" and 3/4" or 1 1/2" and 1/4" and laminate together with caulk . Be certain you buy only the caulk that specifically says it is safe for use with foam as regular caulking will eat foam.
colbyt
Master Chief Petty Officer
When confronted with a similar situation I bought a combination that added up to the value I wanted and stacked them; actually I packed them on edge but the principal is the same.
Swampfox88
thanks for everyones help, glad you said that about the caulk. I was curious as how to mend them together.
