Flywheel sluggish with spark plugs in. Acting like dead battery.
oldsalty1
Looking for a solution:
I found a boat that I like and started doing some testing to see if there are any problems with the O/B. One problem that I found is with the spark plugs in, the starter acted like the battery is dead. With the spark plugs removed, the starter and flywheel spins freely. We changed the starter, changed the battery to a known charged battery, changed the jumper cables (bypassed ignition), bypassed the selinoid too and applied power direct to the starter. All ended in the same result, like the battery was dead. Spin then stop then spin then stop. The boat has sat for 4 years and the powerhead was rebuilt before then with a total of approximately 50-70 hours. 1984-86, 90HP V4, Johnson.
Any ideas before I call in the mechanic to take a look?
Thanks in advance.
oldcatamount
Re: Flywheel sluggish with spark plugs in. Acting like dead battery.
Make sure all of the battery connections are shiny clean and tight. Check the ground wire and make sure it's tight. When battery cables get "crunchy", it's time to change them as they build corrosion on the inside and reduce the voltage flow. Since the motor sat for 4 years, spray some penetrating oil into the cylinders and turn the flywheel by hand to help work it in. Might be a little sticky in there.
HighTrim
Whats compression on the powerhead?
You tried hotwiring a known good starter direct from a know good/fully charged/load tested battery, and she still wouldnt spin with the needed 300RPM?
oldsalty1
the owner has been maintaining the o/b but not running her. he has been using fogging spray to make sure the pistsons didn't seize up. flywheel can be turned by hand easily with spark plugs out. official compression test not done - "poor mans" compression test done (put finger on spark plug hole, while cranking over, there is pressure) and there "seems" to be good pressure from each cylinder. What the actual number is, don't know. For what i am paying for the boat, the o/b is kinda like an extra. I am still going to buy even if the o/b cannot be 100% checked before purchase. All I can say is that the flywheel spins real quick without the plugs in. Seller said ran like a champ before she sat for 4-5 years. I read something about a pressure release valve? Does this o/b have this? Can it be stuck closed?
jonesg
Thanks in advance.
I would shoot some premixed fuel into the cyl's to loosen it up, it just sounds like it got gunked with fog oil.
Flood it, then spin it over with plugs out to flush the oil out.
Do it twice then install plugs and it should fire right up, turn the water on.!
BoatingCop
Also if that doesn't work, you may want to get the starter rebuilt. It sounds like that could be your problem too.
ONERCBOATER
i am leaning towards bad connections to starter.... the other option is that the starter is damaged or the commutator is dirty/oxidized, or brushes worn or spring tension on brushes low. Any of the above will/can cause this symptom. I know that i have disassembled and cleaned up more than my share of starters... partially to "know" that i wouldnt have issues while on the lake, and partially due to symptoms such as you describe. I don't know if there is a post or thread on how to disassemble and clean up a starter for your outboard and then reassemble it. I would offer to do this if anyone wishes for such a thread. I believe that those that have actual manuals for their engines would have this information, but I think we could do a better job than the manuals by adding nice clean clear color photos, and easier to understand wording. Is there any interest in this, or has it already been done?
Sean
