flywheel revoval
biteme12
I have a 1989 v6 175 hp gmc inboard motor.I need to replace the flywheel.Do i need to pull the motor out,or can I replace the flywheel with the motor still in the boat.:confused:
Re: flywheel revoval
Ayuh,... What Outdrive,..??
Is the problem, Stripped teeth,..??
If so,...
Ya gotta pull the outdrive, then the motor...
If you can gain the space to work, the motor can stay in the hull,...
You'll need a few Feet...
Then pull off the flywheel, 'n knock the Ring Gear off the flywheel...
Take the New Ring Gear, 'n pop it in the oven, set to 450? for about 20 minutes or so...
It'll Drop right inta place when placed on the old, but cleaned up flywheel....
The heat will get sucked out quickly, 'n it's there for Good...
Then bolt it All back together, 'n figure out Why it happened in the 1st place....
biteme12
alpha one outdrive,and yes a section of about 4 inches of stripped teeth
Phfantasm
Bond-o is right, but getting the bellhousing off with the engine in place wont be fun, or easy... i suggest pulling the motor off the mounts at least and moving the engine out so you can get to it easier... then you can ispect everything, look real close at that coupler while your there... and realign it
