Flywheel Replacement
Pirate4Life
I've got a 1997 Mercruiser 5.7 EFI (Alpha 1). It looks like I have a couple of broken teeth on my flywheel so the starter is not engaging properly. So I need to replace the flywheel. Before I take this thing apart where should I look to get the specs for my flywheel? (I bought the boat used, so I have minimal original documents/manuals.) I know the serial numbers for the engine, transom and drive. Is there a way I can use these numbers to look up the flywheel info somewhere? Also, do I need to use a Mercruiser part, or can I use an aftermarket part? I've noticed on eBay there's a lot of GM parts out there. I'm new to the boating world so I appreciate anybody's guidance on this issue or any other boating tips you'd like to share.
Bt Doctur
Re: Flywheel Replacement
all you need is a ring gear, it comes off with a hammer and drift, new one drops in place after heating it in an oven.
Ayuh,... If original, yer motor has the small bolt pattern, 1 pc. rear main seal flywheel...
as BD said, ya just need a new Ring Gear....
There's only 2 options,...
The 12" ring gear, which is used for the straight across bolt pattern starter,...
'n the 14" ring gear, used with the staggered bolt pattern starter....
Pirate4Life
Thanks to both of you for your replies. You've been very helpful.
