Re: Flywheel Removal
It may take some time. And I agree with you both, use heat as a last resort,and be prepaired to fix expensive heat related damage.<br />But get a can of WD40, Liquid Wrench or other penatrant, and fill the flywheel inden up with it. Then go in the house and watch the tube. Check it every 4 hours or so,to make sure there is still some penetrant left in there. It may not penetrate. After a day of soaking, tap the flywheel with the rubber mallet a few times. When the penetrant starts to disapear into the shaft,you'll know it's ready for another try with the puller. I have (on a Merc1150) had to soak it like this for 6 DAYS!! But it does werk.
