Jmorrell588
Thread starter- Joined
- Jul 20, 2002
- 61
*Evinrude 1989 90hp VRO Crossflow 2 stroke* <br /><br /> Question, the manual makes it seem so easy to take the flywheel off as well as the nut at the top, it ain't easy and I am going on day 2 of using penatrating oil.<br /> **** So, if I am reading this correct from the manual, I am to loosen the nut on top of the flywheel, then use a puller to pull off the flywheel? <br /> **** Also, where can I get a tool to keep the flywheel from turning when I try to loosen the nut on the top?<br /> **** Do note, that I do not have a impact wrench and I am using a large socket with a large handle.<br /><br /> Jimmy
