Flywheel magnents
jlgl
Working on flywheel. Anyone know how remove magnents from one flywheel to another in a merc 120 hp flywheel. I tried blowtorch and hammer, both are doing damage to magnents. original flywheel magnents came loose and broke into pieces.
profade
Re: Flywheel magnents
Soak the inside where magnets are with acetone, then try hitting top of flywheel with hammer, if it does not loosen any of them then use a small chisel to hit right above magnet on the flywheel in a few spots digging into the metal and they should break free. Do not try to pry on magnet or hit it directly as they will crack.
jlgl
thanks profade
i did try to hit with wide flathead..but thet broke off in pieces..I will try acetone I guess.
kend301
Heat ( not from propane , blow torch or MAP gas) use a paint scrapper and gentle force works every time .
jlgl
I replaced magnets...new problem..the crankshaft key broke off when I ran the boat..so now what?...why did it break and can it be fixed?...
