Flywheel hitting 1 coil pack
Highboy4x4
I'm restoring a 1966 evinrude 5 hp, I've done everything done to it top to bottom. The only problem I'm having is as the flywheel spins it brushes against one of the coil packs just enough to wack the throttle all the way to the off position then spins free again. For the life of me I can't figure our why it's rubbing, and I can't run it because it turns the throttle all the way off. Any ideas? Thanks
welcome aboard. its a common issue on old OMC outboards. just do a search for coil rubbing on this site
hardwater fisherman
The heel of the coil should be flush with the mounting boss on the mag plate. Use a small straight edge or you can run your thumb nail over it to get it flush.
hardwater fisherman
No Title
These two photos are from another thread and show the correct way to mount the coils. Also note too far back is not good and will maybe reduce spark.
Honorary Supreme Mariner
Agreed coils need to be adjusted to clear the flywheel.
Parrothead71
I bought a simple ring from somebody, I'll look for his website, that worked great! I was having the same problem with my 66 fastwin 18hp.
The ring isn't cheap but it was by far the easiest way to set the coils.
geoffwga1
I've always found the easiest and cheapest way is with my thumbnail.
hondam
With everything tight grab the armature plate and try shaking, if its loose you need a new one, the machined surface is damaged.
boobie
F-R, did you ever make and sell those rings or am I dreaming ??
