Flushing OX66 200hp saltwater series.
crazy charlie
No issues, flush once a week thru flush port hose.seen a lot of videos flushing with rid lime and vinegar.Most remove lower unit and run a pump thru there.why not thru the flush port or why not run in a barrel of water/solution??? Most videos had an overheat issue which I do not. Just curious if I am doing enough? .Im in salt and Tststs looked pretty scale free when changing them out. Just curious why such a process?? nCharlie
99yam40
I would think if you start having overheating problems, then you do something different than what you have been doing
