flushing an engine
smacks12
is it possible to flush a 4.3 gl engine by putting some kind of permanent attachments in place of the engine block drain plugs without having to start the engine?
Lyle29464
Re: flushing an engine
You would need to tap in before the thermostat housing to flush the manifolds and just below the housing where a heater hose might be on a car. Not sure you would do a good job that way. hard to flush the entire housing.
Ayuh,.... That's the Last place to consider plumbing Into....
The Drains are very important in of themselves...
Don S
You need to run the engine at operating temperature in order to open the thermostat while flushing. Otherwise the engine will not flush out properly.
