Well fellas, upon further inspection of my project boat I found a 6x6 square hole in the floor under the windshield walk-through. I proceeded to rip up floor and found rotted stringers and water loggged foam. Here are my questions 1: What is this foam for. Is it just insulation or does it help float my boat. Also do i need to replace it and if so what should i use? 2: I have seen and heard you guys talking about composite flooring. Where can i get it and do they have stringer material. Really never want to do this again. 3: What is the easiest way to remove the old stringers without tearing up the hull. Thanks for all your help, without it i would not have gotten this far.
