flooring issue?
mac150
Hi Guys,
I'm looking at buying a 1999 Lund. The only problem that I see with the boat is there were carpenter ants on the floor, maybe 12 or so. The owner swears he never had trouble with them before. He sent a picture with the center floor panel removed, doesn't show any damage. He offered to have an exterminator service it. Any thoughts?
Mike
jadssh
Re: flooring issue?
Hi Mike, What type of Lund is it? I have a 91 Lund Tyee and there are several areas that you should be able to access to look at the wood to see if there is any damage. If the Ants have caused any damage, you should be able to see the fine shavings laying in the corners etc. Hope that helps and keep us advised. John
mac150
Re: flooring issue?
Its a Fisherman 1800. I hired a Marine Surveyor to do an inspection. I should be hearing back within the hour.
Mike
ziemann
Re: flooring issue?
This is an interesting thread- let us know how you make out....
jadssh
Re: flooring issue?
Good luck Mike. Keep in touch with the results.
mac150
Re: flooring issue?
The Marine Surveyor said he saw no sign of ants. The wood is solid with no rot. A couple small dents in the hull, consistent with normal use. The legal papers are in order. He said the boat is used not abused, a solid vessel he would consider owning. So for $200.00 I have peace of mind and a boat in my driveway.:D
Mike
jadssh
Re: flooring issue?
Good going Mike! I just started a post called "let's see some pictures of your Lund" So how bout posting a pic of your new boat. Talk with you soon. John
ziemann
Re: flooring issue?
You are a smart consumer, Mike-
Great investigative work! Congrats on your new baby!
