I picked up a 2245 model zodiac off craigs list, and the floor boards do not seem to fit. When assembled, the 3 pieces seem to be longer then they should be. They extend about 3" beyond the fixed/glued board. The boards are plywood and they snap into the siderails nicely, however I can not get them to flatten out once they are secured at the glued board and transom. I would hate to cut them to "fit" then realize they were right to start with. If anyone has drawings or dimension for these boards I would appreciate the info. Actually all I need is the length of the assembled rear 3 pieces.
If someone has the same boat I would appreciate if you could measure the floorboard dimensions from stern to the glued floor board.
Thank you!
Thank you!
