I have a 19' semi v jet boat. I cut out the floor it was no good. question is do I put it back how it was? where the floor meets the hull whats the best method to glass it together? what materials cloth, mat, biaxial? polyester or epoxy? here is a pic of how it was and how I think I might change it to, what do you think? if I do it the way I might change it to should I put the plastic foam sheet material between the plywood and the hull. I have never done this before and I think I am capable with research and maybe some help from the pros on here. thanks for your opinions, thoughts, and criticism
