floor replacement question
aggie 01
I have a 1979 crest craft deck boat with a 135hp engine on it. the old floor was fiberglassed in.when i go back with the new floor should i refiberglass the floor in ? the cross supports are rotten also they were glassed. should i reglass them also? also i plan on putting shower pan liner down before i put carpet in it.thanks for all yas help.
VeroWing
Re: floor replacement question
If you want a long lasting strong, rebuild of your floor and stringers/supports, then refiberglassing would probably be a good idea.
Jeep Man
Shower pan liner is not designed for outdoor use (UV, cold temp, high temp etc.). You'd be better off to glass it in like before or if you don't want to spend the time, spray in bedliner would be the lesser alternative.
