Floor Covering Other Than Carpet
jiju1943
The carpet on our pontoon is getting a little stained and we are thinking about removing the carpet and installing something different. Any ideas what to use, also how to remove the glue. We love to fish so that is another reason to get rid of the carpet. I would appreciate any suggestions you are willing to offer.
1983 ercoa 21'
I used evercoat skid no more it's a paint with rubber in it you apply it with a roller it will cover the glue .
gm280
I happen to be at a boat store over the weekend and looked at some of the new boats (wow, so way over priced for me). Seems they are using some type vinyl on some of them now. But it would have to be something that doesn't slip like grease when wet or you are in for some precarious fishing... I've used carpet in a few boats and honestly, I never has any issue with fish or stains. And todays carpets, especially marine type, doesn't seem to have problems with fish blood and gut residue like older types... BTIJMO!
HotTommy
jiju1943,
I have restored exactly one old pontoon boat, so my experience is limited, but here's my opinion. I removed everything from the deck and then went to remove the original carpet. The old glue held well and it was very, very difficult to get the carpet off. There were numerous places where bits of the old carpet and glue remained well adhered to the wood deck. .... My research indicated some people had tried various power tool implements (e.g., wire brush on drill) in an attempt to remove the old glue. I quickly discovered that it would have taken many, many hours of tedious work to remove what remained behind. As the majority of the deck is covered by furniture, I left those areas as is. I spent a little time on the walking areas knocking down the high spots in the old glue and carpet. I then glued new marine carpet down. There are no noticeable bumps and I'm satisfied with the finished product.
I thought of and decided against vinyl out of fear it would be slick when wet and hot on bare feet when dry. It would have also required me to do a much better and more time consuming job preparing the deck. Vinyl shows what's beneath far more than carpet. If I had to do it again, I'd again use marine carpet.
jiju1943
Thanks Tommy for the write up, I do appreciate you taking time to explain how you did your pontoon. I just haven't made up my mind yet.
The carpet on our toon is in good shape, it just has a few stains on it and when it is wet it looks even worse. I even though about dyeing the carpet to look better.
rogerwa
I have marine vinyl on mine. The furniture and fences are all on risers so any water, even while washing it, flows directly out the back.. I have never found it to be slippery. While it can be warm, it is never burning hot. A little water splashed on it cools it right down. In my view the best situation is vinyl floor with snap in carpet sections. Best of both worlds..
Redfred1
I pulled the carpet up on my boat; used a wire brush to knock down the bad stuff. Then I applied a good marine paint; then mixed some coarse sand with paint chips. Looks like a garage floor. Should work on a pontoon.
jiju1943
I think they sell the vinyl by the linear foot, could you tell me how wide the vinyl is. Sure would be nice if it were 24 foot long and selling by the foot, I would just need 8 feet of it.
Thanks RedFred, I wish it were as easy as you explained it. :)
jiju1943
Thanks Roger, I really appreciate you looking that up for me.
Fleetwin
We removed the carpet from our 24' Starcraft a few years ago. We installed vinyl and never looked back. I believe iboats has vinyl.
The only tricky part was making sure all the wrinkles were out. We rented a vinyl flooring roller from a local tool rental outfit. Worth the $20.00 rental fee.
