Floor covering as easy as it gets
Ironside
Hello all again I have finaly finnished my refloor after much trial and error. It came time to cover my handy work and I tried a few things #1,rocker pannel undercoat...no good not thick enough,#2, truck bed liner expensive and did not like the end result.#3 I finaly took the wire wheel to all that stuff and put down a one peice vinel anti skid exterior deck material, kicks @$$ all you do is sand with 40 grit clean up dust roll glue on then lay vinel and roll out air pockets 100% water proof I went up the sides 6" front to back perfect finnish "no blotchy or uneven aplication any way I just thought I would share the product is made by DUNCAN if you want to check it out search DUNCAN or ROLLDEK on the net see ya all
JustMrWill
Master Chief Petty Officer
Re: Floor covering as easy as it gets
Couldnt find any wed sites on google search for rolldek and too many with duncan...none with both... :( <br /><br />-JustMrWill
Realgun
We really would like to "see" this here floor. As some of us "me" are going to bew doing some carpeting soon.
f_inscreenname
It will work fine if nothing opens on your deck. A hatch, if it didn't have a trim ring of some sort could be a problem.
JasonJ
I don't know, the two coats of Evercoat No-Skid I applied to my floor is still fine, and it is on its third season. I have dropped stuff, spilled stuff, you name it, and it has been good.
jollymon
Boy you guys are tough. He post and 2 days later you are calling him a o hit and run, troll, just because you can not find the product he talks about.<br /><br />I did a google search on ducan flooring and found this as the first hit:<br /> http://www.ducan.com/products/dek_master.html <br /><br />lighten up and give people a chance, new members have good info to!
TexomaAv8r
I never called him a troll, but I would like to see pics if he has them. I like bright colors and pretty pictures......<br />And it looks as if he miss=spelled in the original post which probably made the google search fruitless
Realgun
I retracted the troll part. :) Here is a way for him to POST a picture though. Please we wanna see.
Ironside
sorry guys was busy with non boat life "bummer" I will get pics soon and yes it works great if you have nothing on your deck that opens below, i ran it down into the sides of my builge though
Ironside
and again i cannot type the product makers name is ducan not duncan there web site is www.ducan.com Check under products and then vinyl dek master
Ironside
cost me $185.00 Canadain to do my deck 17' by 7.5' adhesive and vinyl
Boomyal
Originally posted by jollymon:<br /> Boy you guys are tough. He post and 2 days later you are calling him a o hit and run, troll, just because you can not find the product he talks about.<br /><br />I did a google search on ducan flooring and found this as the first hit:<br /> http://www.ducan.com/products/dek_master.html <br /><br />lighten up and give people a chance, new members have good info to!
Just a bit aggravating when someone makes a post with no supporting detail. The link you provided does not even include the name that Gluton provided.<br /><br />Veteran poster or new, it's not good form to make a post and end it like this:<br /><br />
(edit) Gluton was atoning for his oversights while I was constructing this post. :D
jollymon
Boomyal,<br /><br />
I searched on Google, using Ducan Roll Dek, just like GLUTTON4PUNISHMENT suggested, the only thing I added was flooring and a space between roll and Dek, it came up as the first hit. <br /><br /> I know the link comes to a product with a different name then GLUTTON4PUNISHMENT had, but I was 99.9% sure it was what he meant. I am glad to find out it was!
Boomyal
I guess that makes you smarter than I Jollymon, (seperating 'roll' and 'dek') as well as clairvoyant. ( eliminating the 'N' from 'Duncan') :p
jollymon
NNot smarter, just lucky, a bad typist and reader and 36 hours no sleep! Leaving the "N" out of Ducan, was totally an over site on my part. seperating roll and dek was standard for me. I do alot of searching and found some times you got to give the search egenige a big push, to find what you need. Google is pretty good, but the seach engines on the Tech sites I use for work suck!<br /><br />I would still like to see some photo's GLUTTON4PUNISHMENT, any chance we could get some!
Ironside
No problem jollymon I am borowing a digital camera on the week end sorry for the confusion boomyal
90skichallenger
Actually I think that is a cool product. If I hadnt recarpeted my boat last year I would prolly go with something like this.
Ironside
For all those who scoffed and for those that asked i started a new thread with picd of the ducan rool dek
