Floods out
Sreve67
Starts and runs in yard
Put motor up and take to lake motor will not start
pull plugs and clean will start
Steve, welcome aboard.
Not sure what you are working on, however my guess is an outboard, and since you posted in the Johnyrude forum, its a Johnyrude.
a few things that will cause it to flood
bad float(s)
bad needle(s) and seat(s)
crud in the fuel system
weak spark.
my first suggestion is a complete carb(s) overhaul with new needle(s) and seat(s) and float(s)
then a link and sync.
what is your motor year size etc ,some omcs um maybe 83 or 4 on up also have a fuel enrichment valve that has a small red lever that if turned the wrong direction will flood the heck out of your motor ........lever should be turned back towards the body of the black round cylindrical enrichment valve assembly ,but not sure of your year and hp
boobie
First thing to do is a compression test. Then post a model # ??
