flooding
t.martin
1986 85hp force. all three carbs flood like crazy. will faulty fuel pump diaphragm cause this? it acts like it has too much fuel pressure. is there a regulator for the fuel,besides the floats?
scotiany
Re: flooding
Sounds to me like dirty or worn needle and seat valves in the carbs. I'd get 3 kits from NAPA and rebuild the carbs. Wouldn't hurt to get a fuel pump kit too. Ask to see their marine catalog.
t.martin
Re: flooding
the needle seats are pressed in. the book says you cant replace them.
timfromfc
Re: flooding
I have the same motor and it used to flood all the time. In fact, it took me being towed back in 4 times until I figured out how to start it! I'm slow, but can be taught! :D Does the motor run ok when it runs normally? Are you able to start it when it is flooded? If not, read on...<br /><br />It may not be the same problem as yours, but mine seemed to flood every time I changed the fuel tank, or started it warm with the choke. If you can't get it started when it is flooded, try turning it over with the throttle wide open. I have to remove the cowling and manually hold the carb open while my wife starts it. It only takes a second, and I immediately let go of the throttle. Everything worked fine after that. Good Luck!
t.martin
Re: flooding
The problem is I have never had the motor running right, but I am pretty sure the carbs are ok. I think it is the fuel pump diaphragm. I have found it is very easy to flood by choking it. I am pretty close to giving up on this motor. The sad part is I have two of these motors and they both have good compression. As a matter of fact one of them was just rebuilt, new pistons and rings. I have owned mercs and evinrudes and never ran in to such a querky motor until this force came along.
