aellingsen
- Apr 3, 2006
- 4
Good day to all, <br /><br />I am hoping someone can help as I am in desperate need. Problem started 1 mile off Catalina Island. I was going smooth the whole way out then the boat died. Had someone on the Island look at it and he said it was the air box. Got the boat into a service shop back home. They rebuilt the lower unit for $2100.00 and got the boat back in the water this past Saturday. Boat was running good for the first 20 minutes and then it died (same as in Catalina). If I could get the motor started it would die as soon as I gave it gas. A short term fix was to remove the air box, let it sit for awhile. put it back on and it would start up and run fine for about 10 minutes and then die again. Only when I give the boat gas does it die. Ultimatly the engine won't even turn over and resulting in a tow from vessle assist. I use 87 gas only and think that it could be a fuel fiter problem. When it was in the shop I had them look at the carbuator and they ran a full diagnostic and said everything was perfect. Can anyone point me in a good direction before I give my boat up for another 3 weeks and spend another $2000.00?<br />Thanks
