I recently purchased my first boat. It's a small john baot with a 1981 9.8 Merc. The engine is not working. The spark plugs fire, so I am looking at the carb (this is my first time working on anything with a carb). I've already disassembled it and given it a good cleaning. I feel pretty confident that the problem is that the float valve is sticking closed. With the carb off, I can blow through the fuel line and feel the air passing through the carb. When I turn it upside down (to simulate the float being raised) I feel the air flow being cut off. All this is how a carb should work, right? The problem is when I turn the carb right side up again, air flow does not return until I build up enough pressure and then i5 suddenly releases and starts to flow again.
I assume that means I should replace the float valve and valve seat. Hears the real problem though. I can't seem to remove the float to get to the valve. The pin that holds the float should simply slide out, right? I'm not sure if it's blued in or bent but the pin won't even budge. The ends of the pin look chewed up. Am I missing something simple here? Could I drill out the pin? Any help would be appreciated.
