Re: Float adjustment???
The scketch reads "From the toe of the lip of the float". This would be close to the point the float meets the fuel if it were inside the bowl.<br />It's not just mercarb that is vaugue in it's description, but between everyone here, we will figure it out.<br />The kits (at least the ones I get) have a<br />a small ruller that looks like a carpenter's square in miniture. These are great for presetting the float level before assembly, but I STILL never get it exact the first time.<br />But my advise is to not loose too much sanity here with the float level. As long as it controls the needle valve to allow fuel in,and still shuts off the fuel before it spills-out of the overflow, you should be ok.
