Flo Torq III question
graphicideas1
I installed a Flo Torq III on a 90 2 Stroke with a SS prop. Dealer told me it would help eliminate prop rattle. I installed it but have a slight wobble toward the rear of the prop that i do not have with the flotorq 2 hub. Any Ideas? Why does the flo torq 3 use the long brass sleeve and the 2 use a short one? I looks like the brass sleeve will not allow the plastic part of the hub to tigthen enough.
gss036
Re: Flo Torq III question
May be you have the wrong assembly. There should not be a wobble.
graphicideas1
talked to a tech at Mercury and hey are saying that is the way it was designed. I don't like like it but it did take away the prop rattle noise i had. Do any other companies make a prop hub to eliminate prop rattle?
