Flame Arrestor Cleaning???
Driftwood dreamer
What type of solution can someone recommend for cleaning a flame arrestor??? I think this could be the reason why the boat is not starting.
searay3
Re: Flame Arrestor Cleaning???
Need to know what you are working on. Engine/drive package. If you have the metal one, simply use some spray carb cleaner. If it's the K&N type (Gauze or paper) follow the manufacturers suggestions.
HT32BSX115
Howdy,
If you think the flame arrester is causing your problem, remove it and see if the engine starts normally. Run your bilge blowers at least 5 min and ensure that you do not smell fuel and have a fire extinguisher handy.
btw, flame arresters RARELY cause starting problems......
rbh
I go with either dish soap and hot water and blow dry with compressed air or varsoll soap, hot water and compressed air.
it has to be some plugged for the engine not to run, check carb for lots of crud.
rob
Gary H NC
Brake cleaner spray cleans them up nice too...;)
cooter2506
Brake cleaner is what I use also. BUT that is not your issue. It would have to look like a cat is wrapped around it for your boat not to start
