I looked at an 89 Bayliner with the 2.3 ford motor. The owner says it has a cracked exhaust manifold. He says he took it out on the lake and it idles fine and will rev up in neutral but when you put it in drive it bogs out.
I am a newbie when it comes to boats and i need to know if i can just weld the crack or if I should just buy new manifolds and risers. I need any info on fixing this problem. maybe good website for the manifold parts and info. I have read that it would be better to get new parts then welding the current and risking further problems down the road.
Any info helps a ton. Thanks guys
