Fixing Busted Upholstery Seams
RussWalters
I am looking for some advice on the best way to repair these seams on my upholstery. Are they sewable? Someone told me to put 5200 on the seam, but I have a feeling that would look awful!
If sewable, what would you think I should expect to pay someone who knows what they are doing to fix?
Thanks in advance,
Rusty
chevymaher
Material is already shot. Sew it and it will rip right back out. A round needle and hog nose pliers and just tack it to hold a while.
tpenfield
5200 is not going to fix that. As stated, the material is ripped, not the stitching. Expect to pay a few hundred $ to get it all fixed. Is that the only area?
bruceb58
Hard to tell if the material is ripped or the thread disintegrated. Either way, have the upholstery replaced.
Woodonglass
Yup, it's gone. If You want to try, you could remove the cover, and use Spray adhesive on the back and glue a large backer piece on it once you pinched the seam back together. It would last another season or two, but as stated it needs replaced.
AlabamaNewbie
The last picture is zoomed in enough to see the vinyl tore away from the needle holes, the stitching is still intact.
OP - *IF* it was able to be sewn, the process for an upholsterer to do would be to remove the vinyl, remove all of the staples (which is almost as aggravating as grinding down fiberglass), sew it up (which will require stretching the vinyl to get 1/2" inch in from the current needle holes), reattach to the seat structure with staples. The only cost difference between that and reupholstering is the cost of the vinyl. Then you'll be paying for it twice - once now and once in 3 months when the "fix" pulls out again because the vinyl is too weak and stretched too tight.
RussWalters
Thank you all - seems like replacing the panel is the best route. Fortunately that is the only area that appears to be ripping on the boat.
